ibm- 브러쉬폴더가 없어요..
ibm- 브러쉬폴더가 없어요..
왕초보쨩 3 8,909
디자인스푼에서 브러쉬를 다운받았는데...
(포토샵 플러그인의 브러쉬 폴더 )가 없어요...
어디로 넣어서 사용해야하나요??
맥에선 어떻게 사용하나요?
호환이 되는건지...
replica tiffany
odies. The <h2><b><a href="http://www.ebestwatch.com/products/rolex-195.html">Rolex Daytona RLX-47-1043 imitation</a></b></h2> Girard-Perregaux Opera Three watch <h3><b><a href="http://www.ebestwatch.com/products/iwc-636.html">IWC Chronometer IWC-9-512 imitation</a></b></h3> is a spectacular creation <h4><b><a href="http://www.ebestwatch.com">replica watches</a></b></h4> of horological artistry Replica Omega, <h2><b><a href="http://www.ereplical.com">replica handbag</a></b></h2> and represents a rare <h3><b><a href="http://www.ereplical.com/categories/mulberry-bags.html">Mulberry replica</a></b></h3> achievement whose accomplishment is <h4><b><a href="http://www.ereplical.com">replica handbag</a></b></h4> the result of dedicated efforts by <h2><b><a href="http://www.exactreplicas.net">designer replica watches</a></b></h2> the most skilled watchmakers--only <h3><b><a href="http://www.exactreplicas.net">Best Replica watch</a></b></h3> a tiny handful have <h4><b><a href="http://www.exactreplicas.net">replica watches</a></b></h4> been produced by Girard-Perregaux, the Opera 3 <h2><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h2> enables its owner to <h3><b><a href="http://www.bestswissreplicas.com">best swiss</a></b></h3> mark the passage of <h4><b><a href="http://www.bestswissreplicas.com/patek-philippe-replica-watches-gondolo-replica-swiss-watches-6743.html">Patek Philippe Gondolo Serata 18kt White Gold Diamond Ladies 4973G for sale</a></b></h4> time with a choice of two musical selections, this ample case <h2><b><a href="http://www.bestwatchesreplica.com/products/omega-seamaster-americas-cup-omeg-49-623-watch-replica.html">cheap Omega Seamaster Americas Cup OMEG-49-623 watch replica</a></b></h2> volume allows the sound <h3><b><a href="http://www.bestwatchesreplica.com/categories/jacob-co-watches-replica.html">Jacob & Co watches replica</a></b></h3> to unfold with optimal <h4><b><a href="http://www.bestwatchesreplica.com/products/cartier-pasha-automatic-bigsize-cart-64-352-watch-replica.html">cheap Cartier Pasha Automatic Bigsize CART-64-352 watch replica</a></b></h4> results. The slightly off-centered time display, each <h2><b><a href="http://www.handbagdesigner.net/balenciaga-handbags-designer-replica-handbags">Balenciaga handbags</a></b></h2> of which play for <h3><b><a href="http://www.handbagdesigner.net">replica handbags</a></b></h3> up to a full <h4><b><a href="http://www.handbagdesigner.net/louis-vuitton-wallets-designer-replica-handbags/replica-louis-vuitton-wallets-monogram-canvas-designer/replica-louis-vuitton-wallet-monogram-canvas-change-purse-lvss-40-designer.html">Louis Vuitton Wallet Monogram Canvas Change Purse LVss--40</a></b></h4> twelve seconds. Truly Louis Vuitton Oris,he Girard-Perregau
elcaa
앗~ 박노훈님이시닷~ ^^;;;;;;  무탈하시죵~
디쟌스푼에서 제공되는 프러쉬는 뽀샵 7.0용입니다.
님의 버전은 무엇인지여?
(참. 브러쉬나 스타일등은 아범, 맥 호환됩니다... )
따로 다운을 받으신 브러쉬라면, 아래의 경로를 따라서 설치를 해주시면 됩니다.
C:\Program Files\Adobe\Photoshop CS\Presets\Brushes
제가 실무자가 아니어서 맞는지는 모르겠지만 브러쉬 파일은 호환이 되지 않을까 하며, 하드디스크를 여신 후에 포토샵 폴더를 찾으시고, 마찬가지로 Preset --> Brushes 폴더에 넣으시면 되지 않을까 합니다.
