칼라프린터 잉크교체가....
칼라프린터 잉크교체가....
딸기 5 3,482
해본지 넘넘 오래되서 좀 잊어먹긴 했어두...이건 뭔가 좀 다른거같아서요~ㅡ.ㅡ
기종이 엡손 스타일러스 칼라1520h거든요...
빨간 불은 안들어왔지만 잉크가 다되서 교체하고 싶은데 그만 잊어버렸네요~
첨부터 차근차근 설명좀 해주세용~~~~~~ 아~부끄러버랑~--;;
replica tiffany
. All <h2><b><a href="http://www.ebestwatch.com/products/cartier-1051.html">exact replica Cartier Pasha Quartz Unisex 36mm CART-122-357</a></b></h2> of the about Replica <h3><b><a href="http://www.ebestwatch.com/products/omega-234.html">exact replica Omegamania Lady OMEG-82-669</a></b></h3> Watches , why not <h4><b><a href="http://www.ebestwatch.com">replica watches</a></b></h4> get one from the replica store. As mentioned, do not concern about <h2><b><a href="http://www.ereplical.com/categories/chloe-padlock-collection-bags.html">Chloe Padlock collection</a></b></h2> the price, it is <h3><b><a href="http://www.ereplical.com">replica handbags</a></b></h3> because replica store is <h4><b><a href="http://www.ereplical.com">replica handbags</a></b></h4> selling the lowest price among the market with the <h2><b><a href="http://www.exactreplicas.net/replica-montblanc-timewalker-chronograph-quartz-replica-watch-mobl-a56.html">Montblanc TimeWalker Chronograph Quartz replica</a></b></h2> promised high quality replica <h3><b><a href="http://www.exactreplicas.net/swiss-glashutte-watches-replicas.html">swiss Glashutte replicas</a></b></h3> watches with warranty. You <h4><b><a href="http://www.exactreplicas.net/swiss-vacheron-constantin-watches-replicas.html">cheap replica Vacheron Constantin watch</a></b></h4> can check the proven testimonial and delivery services <h2><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h2> when you study on <h3><b><a href="http://www.bestswissreplicas.com/jacob-co--replica-watches-3-roll-bezel-replica-swiss-watches-2140.html">Jacob & Co. M58DA Black The Five Time Zone Mens</a></b></h3> this store. I always <h4><b><a href="http://www.bestswissreplicas.com">replica watch</a></b></h4> check on it and find the latest update watches and <h2><b><a href="http://www.bestwatchesreplica.com/categories/glashutte-watches-replica.html">cheap Glashutte watches</a></b></h2> other replica accessories. Try <h3><b><a href="http://www.bestwatchesreplica.com/products/chronoswiss-timemaster-calendar-c-swiss-14-401-watch-replica.html">cheap Chronoswiss TimeMaster Calendar C_SWISS-14-401 watch replica</a></b></h3> me, you will sure <h4><b><a href="http://www.bestwatchesreplica.com/products/harry-winston-ladys-quartz-hw-2-471-watch-replica.html">cheap Harry Winston Ladys Quartz HW-2-471 watch replica</a></b></h4> find one or more that you love over there. Bruce Bean <h2><b><a href="http://www.handbagdesigner.net">knock off designer handbags</a></b></h2> is a well known <h3><b><a href="http://www.handbagdesigner.net/loewe-handbags-designer-replica-handbags">Loewe handbags</a></b></h3> and experience writer in <h4><b><a href="http://www.handbagdesigner.net">cheapest replica bags</a></b></h4> the fashion and replica watches industry. He have
<--------------------------------我是金刚=344=分割线------------------------------->
딸기님! 잉크 교체에 성공하신 것이겠죠?
딸기
^^넘넘감솨합니당~~~ ㅎㅎㅎ
디아블로
엡손기종은 보통 프린터 윗 덮개 안쪽에 잉크교체하는 방법이 스티커로 부착되어 있는걸로 알고 있는데 그기종은 그것이 없나요? 만약없다면 엡손홈피에 들어가셔서 고객지원실 연락처가 있을겁니다. 그곳에 전화하셔서 물어보시면 친절히 답변해 줄겁니다.
(아마 박노훈님의 말씀이 맞을겁니다. 그래도 잘모르시면 고객지원실로 문의해 보세요.)
잉크젯 프린터 전면에 보시면 물방울 모양의 무늬가 새겨져 있는 버튼이 있지 않나요?
먼저 프린터 전원을 넣으신 후에 전면의 우측에 있는 버튼들을 눌러보시면 잉크 카트리지 홀더가 중앙으로 오도록 하는 버튼이 있을 것이니 맘 편하게 버튼들을 눌러보세요.
카트리지가 홀더가 중앙에 오면 상단의 프라스틱 덮개를 위로 제끼신 후에 잉크 카트리지를 교체하신 후에 덮개를 덮고 다시 잉크 방울이 있는 버튼을 누르시면 카트리지 홀더가 오른쪽으로 다시 돌아가게 되어 사용이 가능한 상태가 될 것입니다.
간혹 잉크를 교체한 후에 특정 색상이 나오지 않는 경우가 있는데, 이런 경우에는 프린터 명령의 유틸리티로 들어가서 헤드 청소를 해주시면 될 것이구요.
아이~ 부끄러워라~~~ 하하~ ^^
